跳转到主内容
The Samsung Chromebook XE303C12-A01US laptop features an 11.6" screen and a 16 GB SSD hard drive. This small notebook computer allows for easy access to the Internet and can run various web apps.
37 个问题 查看全部
What can I do do fix my chrome book?
I dropped my Chrome Book and now when I turn it on half the screen is white and the other is black. If I bend the screen, a little bit of the home screen will show. It also had colored lines, large black spots, and a white line across the screen. Is there anyway to fix it? My screen lookes like this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
hi my name is allen and i got me a new chrome boo k and i would like to how do you clean it i never have one of these thanks
完成的
添加一条评论
2个答案
最有帮助的答案
Hi, I'm sure you've resolved this by now but your LCD is shattered, it will need to be replaced.
这个答案有帮助吗?
得分 2
添加一条评论
Hello!
It sounds like you have broken the LCD screen. This is an easy repair, so don’t sweat!
Feel the top width of the laptop screen, you should feel a slight ridge. This is where the front screen bezel snaps in. Using a guitar pick you can gently pry the bezel off. From there, there are four screws in the four corners of the LCD screen. Unscrew those, gently pull back the screen to rest on the keyboard. You will see a cable ribbon, gently disconnect this from the LCD screen. Order a new screen per your device specs, connect the cable ribbon to the new screen, screw the 4 corner screws back in, snap the bezel on, and you are good to go. There are plenty of detailed guides on iFixit, for a screen replacement it does not need to be an exact match to your model for you to get the gist of it. Good luck!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
yourstrulybree 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 12
总计 563
