Why is my replacement screen not sticking properly?
I ordered and replaced my busted ipad 3 glass using the instructions i obtained from ifixit. The instructions were very useful and installation was a breeze. I cleaned all the surfaces that the screen attaches to so the tape would adhere better using some light solvent being careful not to damage any internal components. For the first couple days after the repair all was well. The screen however keeps popping up along the bottom edges and I can not seem to keep it from coming up. I tried using some heat where the tape is and placed some weight on the bottom edge but the issue still exists. Please help. Thank you.
2条评论
Make sure it's not the digitizer flex cable pushing the screen upwards. Is it the bottom left corner?
由 Brian 完成的
Same situation with my first fix and the digitized flex cable seems to be the culprit. How can this be solved?
由 Marc 完成的
