跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
After replacing LCD, Inverted colors and unresponsive touch.
Hello,
I recently replaced the LCD and Digitizer on my iPhone 6. On reassembly of the product i found that the screens colors were inverted and in negative form. also the touch on the digitizer was unresponsive. I did some further investigation as i believe it may be the a faulty screen or the plugs not inserted correctly. I tried another screen to rule out the LCD been the issue.
I have found that if i don't plug in the digitizer and only the LCD the colors are fine. soon as i plug the digitizer in the colors change to negative. Could this be a software fault or a fault on the FPC for the digitizer. The phone has not been dropped either.
Appreciate any help you can give
Best regards
Carl
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Well, inverted color scheme, is a software option for that phone. It is possible to turn that off. However, you need to have a responsive digitizer for that to be accessible. Was the second display assembly touch responsive? Where are you getting your parts from? Have you tried cycling the battery?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Carl 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 210
