跳转到主内容
The Archos 5 is an internet tablet with a resistive touchscreen for video, photo, audio, internet browsing and other multimedia applications. This device may be identified by the model # 7501. The Archos 5 device runs on the Android operating system.
2 个问题 查看全部
Why won't my device hold a charge?
I've been charging my device for hours and it continues to run out of battery even though it's on the charger. I'm not sure if it's even charging the device at all. This issue is really annoying. Anyone else have this problem and know how to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Do you see a green light while charging it?
完成的
添加一条评论
1个答案
已选择的解决方案
You should consider charging your device from a different outlet. If that does not help the problem use a different charger. After these steps have been completed and the problem has not been solved we should look internally. A battery replacement is going to be the next approach to take. Please refer to this Archos 5 Battery Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Larsen Real 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 1,060
