跳转到主内容
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
Why won't by tablet charge?
I try to charge my tablet, but nothing happens when I connect my charger. I've tried using my charger on multiple other devices and it works fine, so I know the charger is not the problem. HELP PLEASE!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Possibly, you need a new battery. First before you think you might want to change out the battery, you want to see if your charger is charging any other of your devices. It could be your charger going bad. You can test your battery if you have a battery tester to see how much juice you have on your battery. If it is not your battery or your charger, it could be your daughter board that is going out. You can change it out. I hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
Bad charging port is very common on the Tab 4 you can purchase a in line charging port tester for a few dollars it will show if the tablet is taking a charge or not.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Briana Honeycutt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 236
