跳转到主内容
The third generation of the LG Optimus F subseries, released in June 2013, identifiable by the model number LS720.
Why can't I listen to my headphones even thought the headphones work?
Hi. My LG keeps on losing the sound when I put the headphones on a laptop it work just fine. I put the plug in the jack and when I turn it it the music stops. It usually didn't happen, but now I can't listen to anything while moving
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
It seems as if your headphone socket in the phone is faulty or has broken off the lower mainboard.
You could try plugging in your headphones and very gently (stress gently) apply sideways pressure to the headphone jack in one direction or any other direction and see if you can hear anything in your headphones.
If you can it means that your headphone socket may be still connected to the mainboard and it may be just loose OR it could be that the connectors in the socket have lost tension.
If you hear nothing when you try this it may be that the socket has broken off the lower main board.
Either way the phone will have to be opened to be repaired.
Here is a link on how to disassemble your phone. The headphone socket is best seen at about 9 minutes 12 seconds onwards into the video, when the mainboard is nearly freed from the housing https://www.youtube.com/watch?v=4bf-gYNY...
If you don't feel confident about doing it yourself take it to a mobile phone repair service.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
raulmedina31 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 207
