跳转到主内容
The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
103 个问题 查看全部
Screen replacement, non functioning touch input, Alcatel idol 3 (6039)
I have an Alcatel One Touch Idol three the screen is cracked, the display still works but the touch input no longer works. Could you tell me if I need to replace the LCD and the glass panel or if I only have to replace the glass panel. I have had difficulties finding the part on the internet. Any help on finding or and replacing this would be helpful.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 16
2条评论
My Alcatel one touch idol 4.7, fell from my hand and the screen got cracked, part of the screen is no more sensitive. How do I get a new screen?. I live in Nigeria
完成的
Hello. Buy it from ali express. See here : https://www.aliexpress.com/item/Original...
完成的
添加一条评论
8个答案
最有帮助的答案
you will need to replace everything including the diplay because the Glass and the digitizer are fused together they sit above the lcd display and it is impossible to remove them withought destroying the display.
这个答案有帮助吗?
得分 5
1条评论:
Where would you buy the parts to fix the screen and all because mine does the same thing want to fix the phone
完成的
添加一条评论
This is the only video I could find. https://www.youtube.com/watch?v=YWmuVFr8...
这个答案有帮助吗?
得分 2
添加一条评论
I have an idol 3 with a broken screen and an unresponsive touch but a clear image and functioning clock, internet connection and system update. This sounds similar to yours and I found this link which I shall buy from...: https://www.parts4repair.com/touch-scree...
Good luck, hope it's some help!
这个答案有帮助吗?
得分 1
2条评论:
did you manage to seperate the lcd from the digitizer without damaging the LCD?
完成的
I had the same issue and bought a similar part but this is useless as it is not easily possible to separate the touch screen from the LCD without breaking it. Some people have done it using specific thermal gear but it looks extremely tricky. I ended up buying the full combo (screen + lcd) from aliexpress. For example: https://www.aliexpress.com/item/Original...
完成的
添加一条评论
I have alcatel idol 3 and i tried to open watsapp and it didnt open and i tried to restart the phone it is just restarting but not taking me to the main screen. I dont want to loose the data , photos and videos ..Is there anyway someone can help me fix it? From quite a few days it is warning me that there is no space please clean it...Is it becoz of full memory?
这个答案有帮助吗?
得分 1
添加一条评论
i have also had this problem my screen still lights up but touch input does not
这个答案有帮助吗?
得分 0
添加一条评论
you may find moving stuff (pictures, music and videos) to a SD card frees up some space. I use SanDisk Memory Zone and also move some apps to SD card with App Manager Pro III. Both are from Google Play Store and they free quite a lot of internal memory. If these apps won't load, you may need to uninstall apps to make room, and then if successful, re-install them
这个答案有帮助吗?
得分 0
1条评论:
it is not turning on to add this....
完成的
添加一条评论
I cracked my screen and how can I replace it
这个答案有帮助吗?
得分 0
添加一条评论
I'm trying to take a screen off of a phone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Scott Vandenberghe Youtube 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 12,754
