LG washer wt4870 cw get error code dl
how to eliminate dl error code on LG washer
Hi,
According to this link, error code dl is a lid lock switch error.
http://www.manualslib.com/manual/420924/...
Here is a link which shows how to repair a lid switch assembly.
http://www.repairclinic.com/RepairHelp/H... (click on Cause 1 Lid Switch Assembly Install Help)
To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
If the switch tests OK the problem may be in the control board''
这个答案有帮助吗?
A bit of wd40 near the lock switch and a bit of a fiddle fixed my problem
All I did was unplug the washer for a few minutes, and presto....it worked
这个答案有帮助吗?
That worked. Thanks!
Tried unplugging.. holding the pause/start button numerousbtimes.numerous times.. still no connection.. what's wrong now?
HI there is a switch above the locking device looks like a magnet control switch H4212S could this be the problem.The locking switch is good.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 59
总计 57,337
