跳转到主内容
维修SLR,DSLR以及无反光镜可互换镜头以及拆解指南
48 个问题 查看全部
Removing a Stripped Screw from Canon 24-70 f2.8 II Front lens assembly
Hi all, I bought a used Canon 24-70 f2.8 II, got it for a great price but the front element was a pretty scratched up. So i called Canon and got a front lens assembly thinking i could replace it myself rather than spending 500-600$ for them to do it. The problem is once i took the front ring off i noticed that 2 out of the 6 screws holding the front lens assembly were totally stripped. I tried a rubber band and I tried glue, nothing worked... I took it to a local repair shop and no luck there either.
Not sure what my next option would be. These are tiny tiny screws not sure a dremel tool would be small enough to make that cut. Also, I have no idea where to buy replacement screws for it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Contact Alzo Digital, CT in USA.
Ask for ATG assists/mods/repairs/services.
这个答案有帮助吗?
得分 0
1条评论:
A reversed spiral drill bit will get them out
完成的
添加一条评论
添加你的答案
vladbusuioc2 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 873
