跳转到主内容
Release date: Jan. 24, 2008; 8MP, 3x Optical Zoom, Built in optical image stabilizer system and Face Detection software; DIGIC III Image Processor.
Why is my camera not focusing
when i aim the camera it is out of focus. if i zoom in a bit it will focus
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
In the Canon SX200IS which I'm familiar with, the focussing lens is the last element before the sensor, and this moves in and out on a brass insert which engages in a leadscrew. (See my SX200IS Lens Disassembly Guide for a full description.) It's likely that your lens is a similar design, in which case I would suspect that this mechanism is faulty and only works on part of its travel. I saw an example of a heavily used camera (probably many thousands of exposures) where the thread on the brass insert was so worn as to no longer work. This could be your problem. Not having access to watchmaker's tools, the only way I could fix it was to cannibalise the part from another broken camera.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
bebrouse 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 2,303
