跳转到主内容
第三代 Surface Pro 平板,发布于2014年6月20日。
What is the version of my LCD screen?
Hi everyone,
The touch screen of my Surface pro 3 was broken so i tried to take off the touch screen from lcd but I did not succeed to save the LCD. So now, i try to buy a new one but i don't know the version of my lcd because I inconveniently threw the flex cable between the touch screen and the motherboard. So, is there anything i can do to know the version of my current LCD ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
same, I have a surface 3 that I recently broke, but I don't want to open it without having a replacement screen first, but I don't know which version I should get. any way of knowing how to tell which version it is by the outside?
完成的
Any luck with identifying the version?
完成的
添加一条评论
2个答案
最有帮助的答案
The model number on my Surface Pro 3 is written in very faint writing on the underside of the kickstand.
Mine says Microsoft Corporation Model: 1631
这个答案有帮助吗?
得分 2
添加一条评论
If you type in the actual model number which is on the back of the device you will be able to get a screen type by just typing in #### replacement screen. That will get you the exact replacement screen. For a Surface Pro 3 I think they are all 1631 screens. Look on the back and see if you see Model # 1631. If not just replace your model number in the #### spot.
这个答案有帮助吗?
得分 0
3条评论:
Type in actual model number where?
完成的
I too need to know where I can type in the actual model number.
完成的
google: 1631 replacement screen
完成的
添加一条评论
添加你的答案
Gaetan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 4,940
