跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your LG TV.
replacing of LED Panel
The screen cracked on my 42" 42lb6500 LED TV. I was wondering if there was someone or somewhere I could get another led panel and replace it myself. I live in Ahmedabad, Gujrat. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Hi,
Did you replaced the screen?
What was the cost of replacement.
完成的
Hi did you replaced the screen
完成的
添加一条评论
1个答案
With the original posting almost 3 years old, I doubt an answer will be forthcoming. However, in the generic case, it is normally more expensive to replace a panel than to replace the entire TV with a new one. Most parts suppliers do NOT stock panels. If you are sure that the panel is the problem, save some money and time, replace the set.
Dan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
manojsingh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 420
