跳转到主内容
The Roku 3 (Model: 4200) is a third generation streaming device released on March 5, 2013. Connect to any television or video display with correct input connections to stream available content.
Why won't my remote connect to my Roku 3?
My remote won't connect to my Roku 3. I tried new batteries and moved it closer to the device, and I still can't get it to work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
2条评论
Tried everything batteries -sink- button- would not work. tred turn of wifi and it worked.On my phone to worked. even did undo power. remote would not quit blink on sink.
完成的
Plug Roku device into your television’s HDMI port and connect it to either wired or wireless Internet. Move ahead to the Roku account activation if you don’t already have one. Enter the Roku login credentials and link the device with your account. Roku activation code will be displayed on the TV screen once you power On your device. otherwise visit the link for more tutorials https://www.go-roku-net.com/
完成的
添加一条评论
4个答案
已选择的解决方案
Hi,
Is the status light on the Roku ON? If not have you got the power adapter plugged in and ON?
If the status light on the front of your Roku player flashes once each time you
press a remote button, the problem is not with the remote.
If it does not flash have you tried re- pairing your remote with the Roku unit?
Pairing your remote control:
You can manually pair the Roku remote by following these steps:
(Pairing button in battery compartment)
Prepare your Roku player to pair by unplugging the
power adapter and plugging it back in.
Open the Roku remote battery compartment
Place the Roku remote in close proximity with your Roku
player.
Press and hold the pairing button inside the battery
compartment for 3 seconds.
Wait about 10 seconds for the remote LED to stop
flashing.
Try using the Roku remote again.
这个答案有帮助吗?
得分 3
2条评论:
If only that worked, it would be great. Having tried all the solutions offered here and on other sites, the only thing that ever seemed to work was leaving out the batteries for a month.
Paired automatically when I inserted batteries, but lost it when I restarted the Roku3 device itself.
I will learn the lesson and never reset again. Remote now has a brand new set of batteries waiting for it - in a month.
完成的
Roku tells me that the newer remotes(with earphone jack) are wifi and not IR like most remotes. You can't have more than one wifi remote, but you can use an IR remote with a wifi one. Why would anyone design such a 'feature'?
完成的
添加一条评论
最有帮助的答案
I thought my remote had simply stopped working and then discovered it wasn't bust but I had the same problem with it refusing to pair. Eventually after a lot of failed attempts I noticed that the enhanced remote connects using wireless rather than infra red, so I tried connecting my Roku to my router wirelessly instead of via ethernet cable and voila - it now works perfectly again!
这个答案有帮助吗?
得分 4
6条评论:
Thank you for leaving this post. This has been driving me crazy, and that was the problem. Now I'm back to having Roku stomp on all my wifi traffic. Seems like it's a catch 22. Why can't I have a wifi remote but use a wired connection for internet?
完成的
I agree, it seems perverse that it has to be wireless between the router and the Roku as well as the router and the remote. I would have thought that the router could simply pass the signal on to the Roku via the ethernet connection. Unless, of course, it uses some kind of direct wifi connection that does not go through the router at all but straight from the remote to the Roku.
完成的
same here :)
完成的
What's really annoying is that Roku hasn't fixed this bug with an update, and anytime you try to talk about this problem, they throw the pairing instructions at you. Just want my Roku 4 to have a working remote and an ethernet connection.
完成的
Still a problem with latest Roku devices in 2019. I have to pair every few days. The remote starts pausing, and finally stops working entirely, again and again. Such a stupid design for a simple dedicated remote control! I hate Roku, which has become as arrogant as Microsoft.
完成的
显示更多的1条评论
添加一条评论
Posts about antivirus products are spam, not relevant to the question. Roku has a bug in some models that requires periodic “pairing” of the remote control.
这个答案有帮助吗?
得分 0
1条评论:
So far, I have found some improvement by taping a large piece of aluminum foil behind the Roku on the wall to reflect the remote control signal. But there is still a 20 second delay sometimes when the Roku won't respond to the remote control. I think this is caused by a bug in the Roku (I am a retired software engineer).
完成的
添加一条评论
NBC, stand of National Broadcasting Company is an one of the best broadcasting news channel platform where you can watch sports event, news, update, sports analysis etc. It's also oldest major broadcast network in the United States.
++https://nbcactivat.com/++
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kasey Evans 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 44
总计 66,546
