跳转到主内容
This is a stainless steel, 4 slice toaster oven. The model number is located on the bottom of the device. It has a single rack height and a removable crumb tray.
10 个问题 查看全部
问题已关闭
Why does my oven door open and close so loosely?
My oven door is pretty floppy, the hinge isn't loose but it opens and closes but much more easily than it used too. If I don't hold onto the door until it stops on the counter, it slams down really hard.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It sounds like your door spring has either become unhooked or broken. This is generally due to normal wear and tear not only from use, but also from the heat of the toaster itself. If this is the case, you would have to replace the spring. Fortunately, replacing the spring is a fairly simple repair process. There is a section in the guide for this repair check out the troubleshooting page.
Black and Decker TO1303SB Door Spring Removal/Replacement
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,733
