跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 sim not reading
I'm working on an ip6 that has had one LCI triggered next to the sim slot. Anyways it is not reading any sims, the slot doesn't look damaged. ideas?
I'm stuck on the activation page. Anyway to activate it without a sim?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
3个答案
最有帮助的答案
You Can always connect it to itunes as long as the sim is on the iphone to bypass activation
这个答案有帮助吗?
得分 1
1条评论:
A friend just bought a used iphone 6 (it had the screen replaced by "someone") anyhow... it will NOT read the SIM and cannot be activated. Is it possible to bypass the activation in itunes and set it up (like an ipad) .... that way we could "finally" reset the time and date (I read that is one of the BIG issues with iphones that have been taken apart to have the screen and battery replaced) .... any thoughts?
完成的
添加一条评论
You can try another SIM card. If it still not work, that's the problem of your phone. You need to take it to repair. As far as I know, the iPhone 6 cannot be activate without SIM card.
这个答案有帮助吗?
得分 0
添加一条评论
Hello SAM,
First check from software level to fix your fault,
Settings--> General --> Reset --> Reset Network Settings
Or check with " Erase All Content and settings" Note: All data will be lost on the phone
If the fault couldn't be solved in software level you have to
Hardware Troubleshoot
Check any sim contact missing or bent
  • As you mentioned if the LCI triggered you should have to clean the area with isopropyl alcohol
  • Check the SIM voltage
if non of above could solve the fault you may have to replace AS3922 chip to fix the fault (Sound BGA reworking skills required) in this step if any mistake you made, few functionalities wont work anymore including NFC
Officially, you should required to sim card to activate your phone.
Hope this answer help you to fix your phone by your self.
Good luck!
这个答案有帮助吗?
得分 0
4条评论:
Do NOT do this! You have a water damaged phone with a hardware defect. Attempting to restore has a big chance of bricking your phone and making it permanently unusable.
完成的
Jessa, i guess he already did it & it's now stop at initial setup screen. my answer focused on wide range as someone facing these kind issue in future. i got the point and agreed with you. Thank you!
完成的
Hi Buddhika Mahesh ,
I am not in the IOS, stuck on activation screen.
The sim contacts are looking ok, nothing bent, I can't really reach the area as the sim case cover is in the way.. should I just try to dip some isopropyl on a q-tip anyway?
Replacing chips is out of my expertise.
完成的
Don't do that. dipping isopropyl alcohol is is not safe way to clean the logic board.
Hope below guide will help you to get logic board out for the service
iPhone 6 主板更换
完成的
添加一条评论
添加你的答案
Sam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 19,554
