跳转到主内容
Released in 2012, the Samsung ATIV Smart PC 500T is a 11.6", Windows-based Samsung tablet computer with 1366x768 pixel LCD, 64GB of storage capacity, and a processor capable of running up to 1.8 GHz.
My tablet and keyboard keep coming apart?
The keyboard often stops working when I'm typing
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Why Stock keyboard they tell to change keyboard layout language?
Pls. Help Me....
完成的
添加一条评论
2个答案
已选择的解决方案
Try disconnecting and reconnecting your keyboard, making sure you place it firmly. If it’s still not working try cleaning out the keyboard connections on both the tablet and the keyboard with a dry cloth, checking for any debris, before reconnecting it.
这个答案有帮助吗?
得分 0
添加一条评论
With the tablet removed from the keyboard, push in the release button at the top of the keyboard (which you push to release the tablet) and look at the small plastic hooks on left and right they need to be both undamaged. Typically some people get frustrated and try to pull the tablet free and that breaks off one of the small hooks. If one is broken, too bad, so sad.
If both look the same and one tip or two are not broken off/damaged, then clean the contacts as suggested above and then I suggest you push down evenly when you reinsert the tablet and then sort of gently push down on left and right side top edges of the tablet to make sure the little plastic tips on the holder have best opportunity to hook onto the attaching holes in your tablet's bottom edge.
这个答案有帮助吗?
得分 0
1条评论:
My right little plastic hook thing broke when it was shipped. Is there a way to replace it?
完成的
添加一条评论
添加你的答案
Marissa Santana 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,490
