Why does my camera say ,"No Memory Card?"
Every time I attempt to use my SD750, I get an alert saying ,"No Memory Card," even though there is a card inserted in the slot. There is nothing wrong with the card. Any suggestions? Thanks...M.
Guessing it's not reading the card. Try cleaning it with some isopropyl alcohol. 90 proof is usually what I use
这个答案有帮助吗?
Did you get my last response?
I guess not. All I got was that one
I tried cleaning mine, but no luck. I've tried 3 different memory cards and get the same answer. No memory card. Hmmm? Is it worth repairing or just get a new camera. My phone has just as good of megapixels. Any suggestions? Thanks
Well, did you try cleaning the contacts with 90% isopropyl alcohol, or did you just try different cards?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 5,042
6条评论
No memory card in my camera
由 Laura Frame 完成的
Use the camera to reformat the card.
由 Ong Ec. 完成的
What do you do when the camera says "No Memory Card" and does not show "format" as an option in the menu?
由 Richard Cannon 完成的
When it says no card what will you firmat bro
由 Francis I 完成的
My camera doesn't turn on guess it could be the battery, is there a way to check if battery is good.
由 paetme 完成的
显示更多的1条评论
