跳转到主内容
加入维修社区 - 创建账户
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
Rear Camera Lens Cover
My rear camera lens cover is scratched. I removed the lens cover by taking off the back panel. Where can i get a replacement lens cover for the rear camera?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
已选择的解决方案
Hi
I would disagree. I have just replaced the rear camera lens cover on an iPhone4, by buying a replacement lens cover ( the small circular ring shape) from the internet. Cost was around £3. Fitting it was easy, but bear in mind that the original is glued in place. Also, if you get a replacement, there is a plastic film over the inside (back) of the cover, which will need removing, unless you like all your photos to have that romantic fuzzy look.
New cover is now on and a great improvement over the previous scratched cover.
这个答案有帮助吗?
得分 5
3条评论:
Can someone tell me where can i get the back camera lense glass? Can't find it anywhere :(
完成的
This place sells the back camera cover, see if it works for you, I'll probably be ordering it soon.
http://www.miniinthebox.com/back-camera-...
完成的
Here's another source for the lens cover:
https://www.etechparts.com/iPhone-4-Came...
完成的
添加一条评论
After you open the phone simply use your thumbnails on the lens cover and push firmly -- the glue will give way. Be careful not to scratch the black by trying to pry it with a screwdriver.
这个答案有帮助吗?
得分 2
添加一条评论
Yup, glued into place but replaceable - some more-so than others. Worth a shot before replace the whole back in my opinion. Changed it a couple times with just a little force and the #*% of a sharpie.
这个答案有帮助吗?
得分 1
添加一条评论
I can confirm the lens is easily popped out with minimal force from the back or inside once the back panel is removed from the phone. I don't think it was glued. I popped one out of a relatively new but broken back panel I was replacing and popped it into a used panel I had that had a more scratched lens. I just pushed out onto the bench with a spudger and then pressed the other panel onto it, so no fingerprints were put on it.
这个答案有帮助吗?
得分 1
添加一条评论
Hi Scott, I'd reference this answer that I wrote to a similar question.
Hope this helps!
这个答案有帮助吗?
得分 0
2条评论:
Where can I purchase the back that includes the lens cover?
完成的
Please read the other answer I linked in my answer here. Here's the link to it: Where to order a back panel for my iPhone 4? Unfortunately I can't give more details yet on we will have the rear panel for sale.
完成的
添加一条评论
添加你的答案
scott Fata 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 10
总计 37,005
