跳转到主内容
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
213 个问题 查看全部
Display Code dl Lid
i just notice that my washer is displaying this code. It locks on its own but lid light doesn't light on. And also my indicator lights are also not lite. Example wash,rinse,spin. Now it does run and wash great. Any suggestion where to begin.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi,
This link has info that might be of interest - regarding the dl code
http://homeguides.sfgate.com/replace-lid...
这个答案有帮助吗?
得分 2
1条评论:
jayeff thks . I was dreading it was that. Your info was indeed helpful.
完成的
添加一条评论
If you're like me and don't have the time to replace the entire locking mechanism, you can try what worked for me. I hit the power button to get rid of the code and then the start button to try again; the error would pop back up every time and I could hear clicking of the washer trying to lock. I found that pulling up on the lid when the lock is in a clicking in will cause the lid lock light to turn on, and the load will run like normal. Might not be the best long term solution, but since it's still locked after doing this, it seems wasting time opening up the washer might not be needed.
这个答案有帮助吗?
得分 0
添加一条评论
Ty! It worked! What a life saver ending dread of going to public laundromat!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
enzweilerswho 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 42
总计 14,424
