跳转到主内容
加入维修社区 - 创建账户
Verizon 版 Samsung Galaxy Tab 4 8.0(型号 SM-T337V,也称为 Samsung SM-T335)于 2014 年 4 月 1 日发布。这款 8 英寸平板电脑搭载 1.2 GHz 四核处理器,具有多窗口功能,并配备 300 万像素摄像头。
Why does my tablet charge too slowly?
When I plug in my Samsung Galaxy Tab 4 8.0 it charges too slowly. It takes an unusual amount of time for it to charge to even five percent. It does this when the charger is plugged into the wall socket. What can I do to fix this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
The cause for your tablet charging too slowly can be a drained battery. One way you can do is replace it with a new one. In addition, do not use your tablet while it is charging. Please try to always charging your tablet with its original charging cable, or it may cause damage to the battery and your tablet’s charging slot. Also, try to charge your tablet in a different wall socket to see if it increases the charging speed.
这个答案有帮助吗?
得分 5
添加一条评论
Check the charger...if it only outputs 1 amp at 5volts....check if the phone will accept a 2.0 amp charger ...this reduces the charge times considerably.Most phone chargers are rated 2 amps .If it is 2 amps...try a different charger before you decide to replace battery.
Charging any rechargeable battery requires you to alternate between 80 % and 20% mist of the time and full drain and full charge occasionally....this will extend the life of Said battery.
这个答案有帮助吗?
得分 1
添加一条评论
I have tried different wall sockets,that did not work. I am using the charger that came with the tablet. Since the day I bought the tablet it has charged slowly. I am at a loss as to what to do next.
这个答案有帮助吗?
得分 0
4条评论:
i have the same problem love the tab hate it slow chargin fast draining ...what to do
由完成的
It may be due to the amp rate of the charger....1amp chargers are often supplied because they are cheaper.Try using a 2amp charger like apple use.
由完成的
Done the same thing the technician broke the tablet while trying to fix it so the insurance covered it and I got a new one but the same problem with a BRAND new Samsung Galaxy tab 4
由完成的
Hi I had very slow battery charger changed the charger plug and lead and hey presto full on again. But, slowed down again due to using a powerboard. Plugged into wall socket and bingo back again . I think not to charge while using may be a good option.
由完成的
添加一条评论
If you have a sd card mounted, try removing the card and then charging. Could be a corrupted card.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ofelia Cruz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 32
总计 32,209
