跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
ps4 update bootloop problem.
I bought the Playstation off cl knowing it had a problem. Keeps failing updates. Ive replaced the hdd with ssd, and installed software with several usb drives. i also tried the software its on 2.04 and every thing between current 3.00. Before I have it repaired was hoping there is a fix. I was thinking maybe pulling the cmos battery. the error code is su-30631-3. model cuh-1001a.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
6个答案
You have to upload the full system software not just the update
https://www.playstation.com/en-us/suppor... (scroll to the very bottom of the page)
apologies if you've already done this - but i made that mistake once
这个答案有帮助吗?
得分 0
1条评论:
I used the full 800mb software file of several versions.
完成的
添加一条评论
I have the same Problems. Anyone a solution?
这个答案有帮助吗?
得分 0
添加一条评论
I have similar problem since my son tried to install the update a few weeks ago. we've tried installing the full version oo and although it appered top work, a couple of days later the PS4 just keeps rebooting and saying you need to install the system software.
Will try contacting Sony support, but if anyone has any answers as to why an otherwise perfectly working machine should just fail like this following update, I'd be grateful - so will my son!
TIA
这个答案有帮助吗?
得分 0
添加一条评论
Same problem and no solution.
Meme probleme et pas de solution de sony
这个答案有帮助吗?
得分 0
添加一条评论
Has anyone found a solution? Same problem here:(
这个答案有帮助吗?
得分 0
1条评论:
Have you solved the problem? Thanks
完成的
添加一条评论
In reading online this particular error is caused by the NOR Flash being corrupted. The onle fix listed i have read is to unsolder the flash and decode the dumpfiles.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kyle Simmons 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 3,698
