跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Not powering on with plugged in
Hi, I have a bit of an unusual one.
I have an iPhone 5c that isn't recognising the power cable when it’s powered off. If the phone is on everything works as normal, but if the phone is off, nothing.
I have tried different batteries and charging port to see if they have any affect with no success.
A bit of history, phone has had a screen replacement. No signs of moisture/water.
Original owner said they had always the apple wall plug but had used 3rd party usb cables.
My initial though is maybe a U2 ic but could do with some other input before I go down that path.
Any and all ideas welcome, thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Well, that is a possibility. However, when you hear hoofbeats, think horses, not zebras. I'll admit this sounds unusual. But, before going down the micro soldering path, try teplacing the Lightning dock. Here's parts
iPhone 5c Lightning Connector and Headphone Jack
Here's labor
iPhone 5c Lightning Connector Assembly Replacement
iPhone 5c Lightning Connector and Headphone Jack图片
产品
$9.99
这个答案有帮助吗?
得分 1
3条评论:
Thanks for your insight but I have already tested a new charging port with no success, also the charging port work normally once the phone is on.
完成的
Right. Have you tried a force restart?
怎样强制重启iPhone5
Or backing up the phone, and restoring to a backup?
完成的
Considering I have replaced the battery I don't think a hard restart will help. I will try a full restore once I get the original to remove the iCloud account from the phone.
完成的
添加一条评论
添加你的答案
Duncan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 90
