跳转到主内容
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 个问题 查看全部
Xbox will not power up, power supply light is orange, no POST
Hello, I have an Xbox 360 S that is having issues. One night while watching Netflix, the whole thing just shuts down. No power. So, I try all I can, the first thing I thought is that the Xbox overheated, and it was only mildly warmer than usual, and there was no overheating error code on the screen. It was just fine to a black screen. The power supply's light is orange, which means the power supply is reportedly good, but I'm not so sure. Xbox Support said that it's a hardware issue, and of course they would be glad to take it in for the steep price of $99.99. I of course knew this was a ripoff, considering it is out of warranty, etc. So, this is what the console does now. The light on the power supply is orange. I go to turn on the console, and there is no POST. It receives power, the light turns green on the PSU, and then it shuts off again, not displaying the Xbox splash screen or anything. I have no aversion to cracking the Xbox open, considering it is out of warranty and probably needs a nice clean and repaste anyway.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
My friend had the same problem. take the xbox into a GameStop or what ever retailer like them near you and ask them to see if plug in a new power cable into the console will boot it up. It worked for them and they didn't need to open it up or send it in
Hope this helps
这个答案有帮助吗?
得分 1
添加一条评论
I have old Panasonic 42" Viera plasma th42pv8h tv. One day to other i can't turn on. Switch on TV, led blinking green fast and started blinkin 10 times red. First switch on get a popping sound whitout smoke. I want to fix if it can be. Help somebody or ask a tip, Thank you! i connect the all cable and all prot but not worcking
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
添加你的答案
cad5359 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 4,965
