跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
Fans spinning continuously after SSD upgrade
Following the guides on this site, I upgraded mine to a 500 gb ssd. Unfortuntely the fans inside the machine are spinning like crazy. I have tried using external software to control them but no luck, the hdd temp reading is too high, the optical drive fan is super noisy.
Am I just simply unlucky?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
First did you transfer the hard drives thermal sensor over to your SSD?
Review Step 20 in this guide you are using here. If you did transfer the HD thermal sensor and plugged it back in your should be OK.
If the sensor is plugged in then we need to identify why your fan is going into full blast. Download this app: Temperature Gauge Pro its one of the better sensor & fan monitoring apps out there. Paste a screenshot into your question for us to see whats happening.
FYI: This is the correct guide for this system: iMac Intel 24" EMC 2134 and 2211 Hard Drive Replacement.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Hi,
Just read your post, then I read the "how to change hdd in iMac emc " in repair section of this site. Came across para.10 which states.... Step 10 — Hard Drive
Before disconnecting the thermal sensor cable, take note of its orientation. It is extremely important to reinstall the connector in the current orientation so the fans will not run at full speed. If you have multiple pins on your replacement hard drive, put the connector closest to the SATA connections and closest to the PCB board.
Disconnect the thermal sensor, SATA power, and SATA data cables by pulling their connectors away from the sockets on the hard drive. "
Do not know if this relates to you but if you installed the thermal sensor with the incorrect orientation it seems to suggest you'll get the problem you're experiencing.
Update (10/11/2015)
Hi,
Apologies. You were right, I was reading the repair manual for model 2308.
It states
Before disconnecting the thermal sensor cable, take note of its orientation. It is extremely important to reinstall the connector reversed from the current orientation so the fans will not run at full speed.
11 Edit Step 10 — Hard Drive
Disconnect the thermal sensor by pulling its connector away from the side of the hard drive.
During reassembly, be sure that the thermal sensor connector is connected to set of pins closest to the SATA connectors. If the fans spin at full speed, reverse the connector's position.
It may be that it might also be applicable to your model. The model 2308 only shows 2 wires to the sensor and from what I can see yours is the same. You might try reversing the sensor cable to see if it makes a difference - unless the connector is a one way only fit.
If they are not a one way fit did you disconnect the optical drive sensor cable as well during your HDD replacement? You state that it runs at full speed as well. If you did, try reversing it first and see what happens
这个答案有帮助吗?
得分 1
1条评论:
Hi, thank you for your reply.
The guide i am following is from here: iMac Intel 24" EMC 2134 and 2211 Hard Drive Replacement
Step 13 onwards, does say anything about the orientation, unless i am reading this wrong?
完成的
添加一条评论
添加你的答案
The Reviewer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 4,350
