How can I reset the memory
how can i reset the memory for D630 please i need help
Hi,
the message on the screenshot says to reseat the memory not to reset it. Here is a link to the D630 service manual which shows how to remove/install memory.
http://www.levnapc.cz/ProductsFiles/dell...
Be sure to read and follow all the safety procedures before removing memory. If it still fails after you have reseated the memory then you'll have to buy another memory module. If there are two memory modules you may have to work out which one is causing the problem.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,016
2条评论
What do you mean by reset the memory? Do you mean a factory reset? please clarify!
由 RS Cell and Tech Repair 完成的
https://d3nevzfk7ii3be.cloudfront.net/ig...
that what i maen
由 nagi 完成的
