跳转到主内容
The Samsung Galaxy S6 Edge+ is the larger variant of the Galaxy S6 Edge smart phone.
custom binary blocked by frp lock
?????? i cant used
i traid factori reset but not word
fashit the batery
the cellular said (keanel is not seandroid enfoacing custom binary blocked by frp lock
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 85
14条评论
I have this promblem too it has a warning sign and says custom binary blocked by frp lock and no matter what I do it wont leave that page. it started when I rooted my phone, when I rooted it, the phone shut off then did the warning screen. PLEASE HELP FIX
完成的
I got the same problem with my G S6 edge. I have been up for countless hours over a week searching for a fix. Were you able to resolve your issue?
完成的
any link please for this solution....
完成的
I wanna kill this guys grammer and then kill him
完成的
https://youtu.be/HprnsOIbpJo custom binary blocked by frp 100% solution
完成的
显示更多的9条评论
添加一条评论
9个答案
已选择的解决方案
For phones that say custom binary blocked by FRP lock after root / flashing modified binaries:
You need to put the phone into download mode by keep holding power + volume down and home until you get the light blue screen then enter download mode.
Then you flash matching Samsung firmware on there. Either 6.x or 7.x using downloaded firmware from either updato or sammobile website.
After that you may also need to do a factory reset in recovery mode as well if it still does not boot.
Once it boots go through setup and enter linked google account login as prompted.
Now to bypass FRP lock you use the instructions on this thread:
http://forum.gsmhosting.com/vbb/f777/uni...
Make sure you downgrade from 7.0 to 6.0 if you are on Nougat first before doing the frp bypass trick.
You also need 6.0 android google account APK so that frpbypass rootjunkie APK works.
Do some research if you can't work it out.
这个答案有帮助吗?
得分 25
9条评论:
After blue screen my phone screen showing:
Downloading.....
Donot turn off target
Now what I have to do?
完成的
Use Odin software to flash the Samsung firmware onto the phone.
Guide here:
http://updato.com/how-to/how-to-install-...
完成的
Downloading.....
majeed
完成的
enabled is working
完成的
Just created an account to express my thanks and gratitude for your post, Ben. It was really helpful and helped my situation greatly. I can't thank you enough.
完成的
显示更多的4条评论
添加一条评论
Flash original firmware in odin. Boot up device. Enable developer settings. Select OEM option, enable. Now you can flash custom firmware without tripping the security.
这个答案有帮助吗?
得分 8
2条评论:
Where do I get the original firmware?
完成的
Downloading.....
完成的
添加一条评论
Hi,
you should use Samsung Smart Switch "emergency recovery feature" and it will work fine again. You'll lose all your data but the device will work again
这个答案有帮助吗?
得分 5
2条评论:
i tried it doesnt works for me
完成的
perhaps Samsung has changed something within this process. TRY to send it in as a warranty issue.
完成的
添加一条评论
https://youtu.be/HprnsOIbpJo custom binary blocked by frp 100% solution all samsung done by one click
这个答案有帮助吗?
得分 3
添加一条评论
custom binary blocked by frp lock https://www.crazyhax.com/solved-custom-b...
这个答案有帮助吗?
得分 3
添加一条评论
If you want to unlock custom binary blocked by frp lock then you need to download odin app which will help you to unlock custom binary.
这个答案有帮助吗?
得分 2
添加一条评论
1.Download Update Rom
2.Flash Your Mobile Phone
3.Solved Your Problem
Detail: https://frpapk.com/how-to-fix-custom-bin...
这个答案有帮助吗?
得分 2
添加一条评论
这个答案有帮助吗?
得分 1
添加一条评论
I have fix my issue with samsungcombination.com where you can get firmware file and combination file
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Angel Charriez 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 75
总计 191,930
