跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
mother board repair, water damage
Water damage limited to top of the phone; no signs of any water under the top 5 sockets. there was a bunch of corrosion up there but I cleaned it with non-sweeping ultrasonic cleaner. I'm newbie for soldering but assembling the needed tools for this. the extent of my soldering knowledge is from the recent ifixit videos with Jenna. I could use some expert eyes on this to determine what I need to do; parts I will need. Or practical advice that should send in for repair and learn on some other boards. Phone seems fully functional except for the lcd, digitizer, and likely the two camera sockets. I was able to restore fully to iOS 9.0.2. getting into recovery mode (with use of the home button) and iTunes.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
The camera socket seems to have 1 pin completely burned out, clean again. And I still see some residual damage on other connectors.
Also I recommend flipping the board over, peel off the top shielding sticker to see the water damage below. Touch panel, home button and LCD backlight have relatively high voltage inside the phone, for this reason the chips and connectors are very likely to have water damage around them.
这个答案有帮助吗?
得分 1
添加一条评论
Pictures of the Back
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Breadman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 382
