跳转到主内容
Repair and disassembly guides for Brother printers.
unable to print 51
Brother MFC-665cw
what does unable to print 51 means
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Thanks...unfortunately, the dinosaur was not able to be fixed. Tried all suggestions and finally took it to a professional and they told me it wasn't worth the cost to try and repair.
完成的
添加一条评论
2个答案
已选择的解决方案
Hi
the following link may provide the answer.
https://www.easyink.co.nz/support/brothe...
这个答案有帮助吗?
得分 2
1条评论:
SOLVED
It worked!!! Thank you!
完成的
添加一条评论
最有帮助的答案
Machine off
- Switch on the machine while holding down the "Menu" button, until all the leds are flashing on/off: it's the "maintenance" mode.
- Press 80
- Press the "Mono start" button several times until you see "purge: xxxx"
- Press "2783" in order to reset the purge counter. You will see: "purge:0000"
- Press the "Stop" button.
- Press "99" to exit the maintenance mode.
This may or may not work but it's worth a shot.
这个答案有帮助吗?
得分 3
2条评论:
完成的
This worked for me, thanks!!
完成的
添加一条评论
添加你的答案
Camely Medina 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 24
总计 18,875
