跳转到主内容
加入维修社区 - 创建账户
Nikon's Coolpix S4100 is a 14 megapixel photo and video taking camera with 5x optical zoom and a touch control LCD.
My camera's battery compartment door will not close?
When I attempt to close my battery compartment door, it will not close and lock. What do I need to do? Is the part replaceable?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
When closing the compartment, be sure:
  • that you are using force to close the door, a spring in the door will not allow it to swing shut on its own.
  • that no part of the battery is protruding from the door.
  • that when you are closing the compartment, the door is shut and then slid forward to be officially locked into place.
If this problem persists, you can find a replacement door on ebay for around $6-$10.
Hope this helps!
这个答案有帮助吗?
得分 1
1条评论:
My D750 battery door will not stay closed. It's the thin clip in the camera that has broken, not the door or clip on the door. It's the bit that sits in the camera.
Cannot find it anywhere., It's a simple screw in part too.
完成的
添加一条评论
part no 1k684-884 see amazon $ 10 yellow battery clip
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Haley Heikkinen 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 47
总计 5,869
