跳转到主内容
Repair information for the Beats Studio 2.0 wired headphones. Originally released in 2013. Model number: BT OV STU BLK.
88 个问题 查看全部
Where can I find left inner panel (housing) for beats studio 2?
Hi Guys, My Beats Studio 2.0 headset developed a crack through the left outer + left inner cover (area marked in image above). Could you please let me know where can I find replacement parts for the same? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
Hi Carlos,
If that is the side with the push button, it is very difficult to disassemble. If it's the side with the charging port, I can sell you mine. My pair was sacrificed in an attempt to create a disassembly guide which should be posted in the next few days.
If you're still interested, send me a message and we can work out a fair price.
这个答案有帮助吗?
得分 0
6条评论:
For anyone's information, the guide is here: Beats Studio 2.0 Exploratory Teardown
完成的
Is there a link you could give me to see your video of disassembly. I also need that exact same part
完成的
@andrew I didn't take a video during the disassembly but the guide I made does a pretty good job of giving you an idea. Which side did you break? I only have the parts from one because the other I had to drill into
完成的
I need the inside plastic piece if you (or anyone) still has it. Please and thanks.
完成的
@noknic I sold my set a while back. There's a pretty sprawled thread somewhere else on this topic that you might have some luck posting on. Titled something like "won't turn on"
完成的
显示更多的1条评论
添加一条评论
添加你的答案
carlos9175 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,154
