跳转到主内容
The Samsung Galaxy Tab 10.1 4G (T-Mobile Model: SGH-T859 / Verizon Model: SCH-I905) was released on November 16, 2011. It is a tablet that comes installed with Android 3.2 Honeycomb and can access mobile data via a 4G carrier network.
13 个问题 查看全部
Why will my camera not take (clear) pictures?
When I take pictures with my camera, they come out blurry.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
When i take pictures with camera they comebout blurry
完成的
My camera not working properly, please do something
完成的
My camera not working properly please do something
完成的
Yes camera is not clear when pictures are taken
完成的
添加一条评论
2个答案
最有帮助的答案
If your camera is taking pictures but they aren't coming out clear, likely the lens needs cleaned. Fingerprints, dust, and even makeup smudges can result in blurry pictures. Use a glass-cleaning cloth or a cotton shirt to wipe the lens of thoroughly. If your pictures are still blurry, check your camera settings to see if anything is out of the ordinary. Adding a flash for pictures in dark areas generally helps with the clarity of the picture.
If your camera is not taking pictures at all, there could be a problem with your touch screen or with the camera itself. If you're having problems taking pictures entirely, check out the troubleshooting page.
这个答案有帮助吗?
得分 4
添加一条评论
Because the samsung compuny is not a good divice
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Curran Yarano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 10,179
