跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
问题已关闭
Post water-damage, the home button stops working intermittently.
Both Touch ID and home button intermittently stops working on my phone after it was exposed to water.
Is it safe to replace the home button? Some research on internet says that it'll mess up with the upgrades on iPhone, like, I won't be able to upgrade my iPhone. Is that true?
Is it safe to replace home button on my iPhone 6 Plus 64GB?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
No. If you replace it you will get error 53 when you try and update your phone. The original touch id home button is tied to your motherboard.
You could try cleaning the connectors for the home button and see if that helps. There is the one on the motherboard and then other is on the flex by the home button. Just use some isopropyl alcohol and tootothbrush/cotton wool bud and give them a gentle scrub. The water damage may have left some deposit/corrosion that is causing them not to function properly.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 67
