跳转到主内容
Repair guides and support for the line of photo inkjet printers by HP.
289 个问题 查看全部
Screen says there is a jam, non seen, where to start?
I have a HP Photosmart 2610. The screen indicates a carriage jam, to open, clear the jam, close the door and press the OK, and resume.
The resume however is just back to the same jam screen.
Where to start?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
If you have completely cleared the jam, I would reset the printer. The manual should explain how to do this. Or you can try shutting it off and removing it from power supple for a minute or so then re-connect.
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
If you've done all the HP-recommended steps and the ink carriage seems to slide easily with the printer off, there's one more step you can try, if you don't mind getting ink on your fingers.
With the printer door open and the cartridges out of the way, see if your printer has an inkjet wiper tray that sits under the cartridges on the right side of the printer. The tray should slide easily backward and forward, at right angles to the print carriage, with just a little hesitation when the wipers go under a scraper bar that sits behind the carriage.
If the tray feels sticky, ink may have accumulated in the tray's guide rails. (My c4385 had printed almost 9000 pages when this happened.) You can clean the rails with cotton swabs and rubbing alcohol (I used cotton balls, a hemostat, and cheap vodka). I didn't go nuts, just cleared where the moving parts slide. I was careful not to get alcohol anywhere where ink doesn't normally splash.
When you've got the tray moving smoothly, make sure you remove any stray cotton fluff, especially from the rubber wipers. Then close up the printer and print a test page (On the c4385 press the Cancel and Green buttons). This cleared up the issue for me.
这个答案有帮助吗?
得分 0
添加一条评论
My hp 2545 deskjet printer continue display paper jam no paper inside the printer
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MTL 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 1,321
