跳转到主内容
First generation children’s tablet released in 2014. The Kurio Xtreme is an internet safe, Wi-Fi capable device with a motion-sensing front camera.
10 个问题 查看全部
Why isn’t my Kurio charging?
Why is my Kurio Xtreme not charging? I plug it in to the cord which is plugged into the wall, and it still does not charge.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
4个答案
已选择的解决方案
The problem could be with the charging cable, the charging port, or the battery. Try using the charging cable on other devices to see if it charges them.
The problem could also be that the charging port is loose or broken, which means that you will need to replace it.
If the issue is simply that the battery level indicator is malfunctioning, resetting it may solve the problem. To do this, plug the Kurio into a power adapter, press and hold the power button until the Kurio turns off, continue to hold the power button until the battery icon shows up again, release the POWER button, and press again the POWER button again to turn the Kurio back on.
If none of these suggestions helped, the problem may be a faulty battery, which will need to be replaced. You can visit the troubleshooting page for additional assistance.
这个答案有帮助吗?
得分 3
添加一条评论
It won't cut on or charge
这个答案有帮助吗?
得分 3
1条评论:
My kurio is not turning on and not chargeing
完成的
添加一条评论
My Kurio got lost a Thew days a ago give me ideas were my Kurio could be
这个答案有帮助吗?
得分 0
添加一条评论
Hi... my kurio 7 stop to working..it isn't charging.. i bought it a few months ago.. its new and doesnt work.. i would like to know how i can replace it? Thank you
这个答案有帮助吗?
得分 0
1条评论:
And why it stops charhing and working???
完成的
添加一条评论
添加你的答案
Kyle Watkins 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 10
总计 8,981
