跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Good signal but poor call audio and 3g internet speeds. Any ideas?
I have an iPhone 5, working fine except that even when the signal strength indicators show a good signal, the phone had poor audio quality on cellular calls. Also slow internet speeds. It seems that the signal is being measured as being good but in reality or somewhere down the signal line it's degraded. If anyone has any ideas I'd be really grateful to them.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Who's your carrier?
完成的
It's giffgaff/o2.
完成的
添加一条评论
2个答案
最有帮助的答案
could possibly be oily finger marks inside if its had a repair? get some iso and clean down any fingerprints or residue on the motherboard and surrounding parts
这个答案有帮助吗?
得分 1
1条评论:
Thanks ProTech. I used a liquid degreaser from ALDI. I hope that would have the same effect.
完成的
添加一条评论
I opened the phone last night and noticed a few things so I had a tinker and managed to solve the problem. The three things I did were to clean with a degreaser as protect suggested, the cellular antenna connections and the point at which the antenna cable connected to the motherboard; there was damage to the antenna connector furthest from the lightning port so i scraped off a millimetre of the black coating and reconnected it ensuring it was trapped under the ring and firmly screwed; I suspected that the antenna cable beneath the plate near the battery connector should have had a foam pad on top to prevent shorts with the plate so I stuck a few sq milimetres of gaffer tape onto the underside of the plate. As is usually the case with me I'm not particularly methodical so I can't say which one solved the problem but so far so good. If it returns the first thing I'll do is to renew the antenna.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
adrianlambert 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 105
