跳转到主内容
华硕所制造的塔式台式机和一体机的维修和支持指南。
no signal from computer to moniter
Their is no signal from my Asus essentio to the monitor . The monitor is working fine as I have cctv cameras attach to monitor and it is displaying them fine, I have also checked cables which are all fine. This has lead me to believe that this could be the graphics card . I have taken a look inside the computer and I can t see the normal set up with a removable graphics card attached to the vga port so I am now wondering if the whole motherboard needs replacing. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
haguehags ,
Hope This answer will hep you to get idea to fix you PC
这个答案有帮助吗?
得分 2
1条评论:
this isnt hel[ full
完成的
添加一条评论
Greetings,
Check the monitor for which type of input signal it is currently set for.
- there should be a choice within the set-up options for Dvi, HDMI, Display port or whichever cable type the Pc is connected to the monitor with.
- insure that the cctv cameras are not set as the default source.
Hope this helps in attaining a signal.
这个答案有帮助吗?
得分 1
添加一条评论
asus pentium3 power ok ram clean ok showing signal ditected
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
haguehags 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 4,507
