跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Bypass icloud by replacing storage?
I recently bought an iPhone 5 from craigslist, completely unaware that the activation lock was even a thing... So long story short I have an iPhone 5 with the iCloud activation lock. I tried to restore it with DFU mode because I figured that would work, but that didn't really do anything aside from un-activate it and update it to iOS 9 (I think). So my question is, with my limited knowledge of iPhones, is there a part (ie the "SSD" for the iPhone, I know it's probably called something else) I can replace to essentially make it a new iPhone? It seems to be void of all defects part from this. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Not any way at all that I'm aware of. Believe you me, I've been working on fixing this for awhile
这个答案有帮助吗?
得分 2
2条评论:
Hmm. Apparently broken (usually battery and screen- which I have both of) iPhone 5s go for like $20-50 on eBay. I think I'll just buy one of those.. I already contacted a seller, he said that it isn't activation locked and his problem with it is the screen is broken and it won't turn on.. Optimistic!
完成的
Uhh.. Well it's a possibility. Definitely a crap shoot, if you're buying on eBay. Buy, maybe? $20 for a phone with those problems, is definitely a great deal. However, it's my experience, if things are too good to be true, there's usually a reason
完成的
添加一条评论
添加你的答案
jacobkuca1 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 959
