跳转到主内容
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106 个问题 查看全部
问题已关闭
Why the screen can not turn on?
My ipad3 problem is
- black screen, i try to see with torch, there is no picture at all (apple logo, etc)
- iTunes not detect when screen attached, only dfu mode will detected.
- if i remove the screen, iTunes detect it normally, just need respond for trusted the device.
- if i remove the screen, and try to charging, there is a beeping sound repeatedly.
- i've tried to replace the battery, LCD, do hard reset,
Please help, Please help, :'(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try to connect it via DFU-Mode and reset the iPad.
这个答案有帮助吗?
得分 0
2条评论:
thanks for reply,
I have tried to connect to itunes in dfu mode and detected. Then I unplugged the usb and do a hard reset, do not produce results, the screen remains dark, then I plug the USB cable back into the laptop, ipad are not detected by itunes.
I do not dare try to do a restore, because the customer forgot his icloud email and password :(
完成的
Well, he can either lose all his data or lose his iPad.
You should try to check whether the cables are all connected correctly.
Maybe you just got a broken Display and need another one.
If resetting it while in DFU-Mode isnt helping, you should try an other Display. You still can send it back in and get your cash back, if thats not the solution for your problem.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 103
