跳转到主内容
1.4GHz (or 2.1GHz) Processor, 2GB (or 4GB) RAM, 128 GB memory, 13.4" display
10 个问题 查看全部
问题已关闭
The charging problem in Dell Adamo 13
Hi team,
Mine is Adamo 13. The charge seems loose at the point connecting with laptop. The charging light flashes. Now I cannot use my laptop when it is charging because it should avoid movement to charge smoothly. What should I do to firm the charge?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
i didn't understand the question , if the charger is loose u can open it and change the cable not that hard
if the laptop charger slot is loose u need to dissemble the laptop and replace the power slot or hold it with super glue .
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 106
