跳转到主内容
An entry level Android smartphone from Tracfone released in mid 2013.
28 个问题 查看全部
unfortunately google search has stopped working-cant text
suddenly got message-sorry! unfortunately google search has stopped. can no longer text
回答此问题 我也有这个问题
这是一个好问题吗?
得分 106
14条评论
Thank you so much they always say we.are never alone god bless
完成的
I never setup a web page to sell products only to play games now I need to pick out a new user name as mine is to old. Which search engine isthe easiest to work with? I really feel intimidated trying to set up something I know nothing about. I really need some advice and help.
完成的
Clearing the data on google search, powering off and taking out the battery for a minute fixed this for my phone. Thanks!
完成的
Systems settings/ Apps/ Google search/ Force stop/ Clear data.
Result? No more "Unfortunately, Google search has stopped".
Keyboard will be reactivated within a few minutes.
完成的
Just started this crap today with my f6. without this post id be screwed. Thank you. was indeed the problem
完成的
显示更多的9条评论
添加一条评论
8个答案
最有帮助的答案
I called Virgin Mobile 888-322-1122 and they said it was a google problem and gave me a number to call that did not work right. The message appears every three seconds on my phone and I cannot do anything. Been happening for over a day now. I have managed to disable tons of things but to no avail.
Update (10/02/2015)
ok, I got it fixed, I have an LG Optimus -- I went to settings, Apps, scrolled to the right to All heading, scrolled down to find Google Search and did "clear data". Turned off phone and turned it back on.
这个答案有帮助吗?
得分 28
18条评论:
thank you sooooooo much!!!! fixed it-I am a happy person again...thank you again!
完成的
You are an awesome person for posting this fix! Thank you and God bless you Zalman131313. This just started today and nothing else I did could fix it!
完成的
Me too! Thank you. I had chatted with support and they told me I would need to get it in for repair, so I am very grateful!
完成的
Thank you so much!
This was a very easy fix that no one could help me with.
完成的
Thanks so much had exact same problem. I spent two hours with Virgin Mobile and Google and they could not fix it. Saw your post today and now fixed....Thanks again.
完成的
显示更多的13条评论
添加一条评论
I had this problem also, if you go into settings and languages and uncheck google voice it will fix the problem.
这个答案有帮助吗?
得分 5
5条评论:
Worked in a flash after other fixes failed - THANK YOU!
完成的
Thanks. This worked for me.
完成的
I fixed but again same problem
完成的
forever thankfull. it worked when nothing else did
完成的
Thanks you soooooo much
完成的
添加一条评论
Fortunately blackgold and stopped unfortunately Google has stopped unfortunately pictures of stopped unfortunately enough how does it get fixed
这个答案有帮助吗?
得分 1
1条评论:
i dont know why google is so popular and in the same time they have so many problems when people use it , some of my problems always giving me message google stopped responding, why is that ?
完成的
添加一条评论
After clearing the data turn phone OFF !!! Take out the battery wait about a minute then put it back in an turn it on.
这个答案有帮助吗?
得分 0
2条评论:
完成的
My friend had the same problem and asked me if i can solve it i looked on web and solved it she thanked me but i want to thank the website from where i got the help. Very useful Derek from Goa
完成的
添加一条评论
how to correct this problem with my handphone when is lags with the message unfortunately, google search has stopped.
这个答案有帮助吗?
得分 0
添加一条评论
It doesn't even type,do
这个答案有帮助吗?
得分 0
添加一条评论
on my lg phone this is how it was corrected, go to settings, then to language & input, and un check the google voice typing and voila done
这个答案有帮助吗?
得分 0
添加一条评论
my google service has stopped working on my android mobile phone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mrs L 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 8
总计 49,402
