跳转到主内容
加入维修社区 - 创建账户
Released in 2011, the Oster Blend-N-Go My Blend is a single beverage blender. Its model number is BLSTPB-XXX-000, where the "XXX" varies with the color of the device.
Why won't my blender turn on?
My blender is plugged into a power outlet, the arrows on the bottle line up with the arrows on the base, and the blade assembly is fully attached, but it still won't turn on. What should I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
9条评论
Brand new Electrolux eab7300s won't start! We set it up according to the six steps. The lights flash on when we put the blender onto the stand. Any given button we press lights up. But the blender never starts.
Help?
完成的
Hi Nuriya OSWALD,
If it is brand new, consult the warranty statement that came with the blender to find out what you have to do to make a claim for a warranty repair or replacement.
完成的
where the power
完成的
my blender not working
完成的
Hello I recently last week bought a Kenwood blender BL440 brand new one
and used it once to make juice but I have tried to use for the second time ,
to my surprise it's not powering on.
What might be the cause?
完成的
显示更多的4条评论
添加一条评论
1个答案
已选择的解决方案
This problem can stem from both the blender or even the circuit powering it. First ensure that the outlet you have your blender plugged into is powered and not "tripped". Most kitchens have what are called GFCI outlets that can trip and cut power to appliances. Once you are certain your device is receiving power, remove bottle and blade assembly; then depress the two black micro-switches inside the base of the blender. If your blender still won't turn on then you may have a faulty motor or motor connection.
Also, refer to the My Blend Troubleshooting Page.
这个答案有帮助吗?
得分 7
8条评论:
where the power
完成的
Thank you so much FYI. It actually worked on my HAIER Blender which wasn't working for ages, all I did was just depressed the micro switch and it worked.
Thanks again.
完成的
Will this work for a blendjet? Because I can't get mine to work, and I've already trouble shot the %#*@ thing.
完成的
Still not working I used it 4 times and now it’s not powering on
完成的
Do I have to buy another motor
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Walter Hernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 32
过去 30 天: 88
总计 150,470
