跳转到主内容
加入维修社区 - 创建账户
一款配备双摄像头的 8 英寸电容式双核 Zeki 平板电脑。该设备的型号为 TBQG884B。
Why does my Zeki tablet not turn on with out a charger?
Looked in the settings and it says that the battery is 100% charged. What do you think the problem is?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
已选择的解决方案
Try to reboot your device. Switch it off and do not use for 10 minutes, this process will refresh the software which is installed on your device. After that switch it on again. If it doesn't work, it might be the problem of the OS. You have to connect it to you PC and repair the OS.
If it still doesn't work, maybe the battery is dead. You have to replace your battery.
这个答案有帮助吗?
得分 3
1条评论:
Thanks Zihao!! You were so helpful.
由完成的 分享
添加一条评论
This sounds like a faulty battery which will need replacing.
这个答案有帮助吗?
得分 2
添加一条评论
You could also try to cycle the battery and revive it. Turn the tablet on and let it die completely. Then charge it completely with the device off. Repeat this and you should get longer cycles after several iterations.
这个答案有帮助吗?
得分 2
添加一条评论
Just got my tablet three days ago. And now I can't get it to turn on
这个答案有帮助吗?
得分 0
1条评论:
Hi, What happens when you connect the charger? Do you get any indications that it is charging? If so let it charge for a while then try turning it on. If nothing happens when you connect the charger, read the warranty notice in the user guide to find out what you need to do regarding making a warranty service for a faulty device.
由完成的 分享
添加一条评论
添加你的答案
Mark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 1,036
