跳转到主内容
加入维修社区 - 创建账户
型号A1288,闪存容量:8、16及32GB
Home button replacement problem
Hello,
I am trying to replace the glass from my ipod touch. I have the front panel out and the glass from the plastic surroundings and I am ready to put the new glass on it. Now there is a small question. The glue that I got with my glass, also covers the place of the home button. Is it a problem that my home button is glued to the platic frame, so will there still be connection? Or do I need to take of the glue from the home button?
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
why is the home button glued to the frame??
maybe i didn't got it right - but when you glue it to the frame - how should it work??????
so, yes - remove the glue from the home button
这个答案有帮助吗?
得分 0
添加一条评论
maybe you had a cover on the glass that has to be removed...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Niek Bronswijk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,415
