跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
295 个问题 查看全部
ipad is showing red battery charging not turning on or charging
When plugged in my ipad is showing battery icon with 4 red vertical stripes and then goes to show apple logo, then blank, nothing. If the power cord is removed the device is not responding. please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
最有帮助的答案
If it has never been opened, then you may have damage from non-Apple charger usage on the tristar (U2) chip. This is pretty difficult to repair due to positioning of the chip and heavy underfill. Rule out physical damage to the charge port itself. It is unlikely to be the actual battery.
这个答案有帮助吗?
得分 3
3条评论:
Its been working fine for almost 2 years. I have always used the genuine apple charger which came in the box.
完成的
@jessabethany could damage to this chip cause the ipad to only charge to 1%?
完成的
iPad Air charging problems are turning out to be more complex than the other U2 chip based lightning charger devices. They are starting to fail all over the place. U2 replacement has not been solving many of them. My guess right now is that the problem is a failure of the PMIC to transfer charging from charging while off to charging while the device is on.
You can try to put the device into DFU mode, then monitor charging with a usb amp meter. It may charge past 1% while in DFU mode and then you can try restore.
完成的
添加一条评论
添加你的答案
Anish Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 5,012
