跳转到主内容
加入维修社区 - 创建账户
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
LCD screen problem and question mark
my macbook pro screen has stripes and question mark.. what likely to be the problem.. please help?
sorry for bad english
http://s.kaskus.id/images/2015/09/28/709...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi,
question mark - cant read OS X, bad instalation, HDD problem or HDD cable problem
stripes - LCD cable, LCD or graphic card (reballing) - try to connect to external LCD
这个答案有帮助吗?
得分 4
2条评论:
thanks for the answer.. i am gonna try to replace the hdd, then connect to an external LCD... is there any possibility mac can read windows hdd ? so I can make sure the problem is the hdd or the cable...
完成的
You need to format it.
完成的
添加一条评论
To fix the question mark replace the hard drive. If that doesn't work it is probably the SATA cable which is connected to the hard drive that's the problem. Had the same problem myself. Couldn't figure out what the problem was untill I actually tried to replace the cable.
这个答案有帮助吗?
得分 3
2条评论:
thanks for the answer.. I hope it's only the SATA cable... can windows or linux read the mac harddrive..?
完成的
I don't think so. You will have to format your harddrive and install windows. You can drop by your local hardware store and and them to chech your harddrive. If it's nothing wrong with it, change the SATA cable.
完成的
添加一条评论
添加你的答案
cnurrohim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 436
