跳转到主内容
加入维修社区 - 创建账户
The Sony VAIO VPCEB4AFX is a 15.5-inch laptop computer released by Sony in April 2008. The laptop was only sold in a gunmetal black color.
laptop won't open when battery is less than 50%
i have sony vaio laptop when i turn it off with half battery charged or less and try to open it again it won't open battery light red and power light green when power button is pressed and some noise heard like fast clicking ; it turn on after i put it in the charger or sometimes remove the battery then charge it how to fix this and why it happening ? pls help ...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Hello starskh,
Try to calibrate your laptop battery
This link will help you to calibrate the battery your self
这个答案有帮助吗?
得分 1
4条评论:
idk i'll try too but the laptop doesn't shut down unless it reach 7% it happen only when i shut it down when battery is low
完成的
still the same , do u know how to flash my bios VPCEH36A , insyde h2o R0190Z9
完成的
Before flashing the BIOS, better to check the notebook with new battery. if you have PLC knowledge you can reset the EP ROM inside of battery ( note recommended to touch silicon inside of battery if you haven't idea of Li power cells )
完成的
i never opened battery before i'll try to replace it first and see if that fix it or not , thx for ur time :)
完成的
添加一条评论
添加你的答案
starskh 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 37
总计 670
