跳转到主内容
2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor
106 个问题 查看全部
Which antenna goes to which connector on the Airport / Bluetooth card?
The take apart isn't labeled as to which antenna goes to which connected on the Bluetooth / Airport card. Cable colours are indistinct and unreliable
Which connector does the Airport antenna connect to?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Here's the image for the teardown: And the associated link:
Teardown
Be sure to check out step 10. The airport antenna has been moved in this pic. to the other side of the mini, but you can trace the cable to where it connects on the bottom left of the airport/bluetooth board, from this pov.
这个答案有帮助吗?
得分 1
1条评论:
完成的
添加一条评论
I don't think it matters, except for the ease of routing the wires...I usually note that 'memory' in the wires will indicate which goes where.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nonono 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,728
