跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
iPhone 4s battery life is only 5 hours with new battery
My battery seemed to die after 4 hours, so I replaed the battery.
Now after a full charge I still seem to get only 5 hours.
The only thing running is phone service, Facebook notications and messenger.
I did notice the phone getting warm, but not hot to abnormal.
Any suggestions on what the problem may be?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Where do you get the battery from? Maybe the battery has been used or it is a fake one. Suggest you choose a reliable supplier like hcqs.cc to get a original iPhone 4s battery.
这个答案有帮助吗?
得分 1
2条评论:
the first battery was an ebay battery. i thought that it could be just as bad as the old one.
the new battery is from ifixit.
no change.
完成的
Yes , the reliable supplier is very inportance
完成的
添加一条评论
It is worth buying a battery from a reputable supplier, eBay batterys can be all over the place.
But you would expect even the poor quality battery lasted longer to start with.
I would do a hard reset (DFU ) https://discussions.apple.com/thread/526...
Make sure you back up first
After restarting turn off everything that uses battery power. wi-Fi, Bluetooth. See how long the battery lasts for.
If you still having problems, probably you need to a get a repair shop to test the draw from logic board.
James :)
这个答案有帮助吗?
得分 0
1条评论:
The only thing that makes it last longer now is to turn the 3G off.
Now it lasts 6 plus hours.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 147
