跳转到主内容
HP Envy TouchSmart 15, model 15t - j000. Release year 2013.
20 个问题 查看全部
My battery life has reduced significantly.
My battery life percentage runs out more quickly than it used to. Why is that?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
The battery after many charge and discharge cycles will lose it's ability to hold a charge. Extreme changes in temperature can also reduce battery life, as well as keeping it plugged in all the time. You should let the battery completely discharge once and a while to help it have a longer life. If the battery is unusable for your needs, you should replace it.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Giovanni Morales 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 380
