跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
GPS does not work.
I opened my phone up a few months back to fix a home button issue I was having, and ever since then (it seems, I don't know what else could have done it) that my GPS doesn't work. I also get spotty cell reception at times. I have done everything regarding a possible software fix (literally everything) and it hasn't solved the problem.
Any thoughts on what this could be? I've checked screws and connections, they all seem fine. Does my antenna need to be replaced? Any thoughts on this are appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
iPhone 6 主板更换
Step 30-32
这个答案有帮助吗?
得分 1
3条评论:
Are you suggesting to replace the antenna in the top right corner?
完成的
No, check the 2 brackets.
完成的
check the brackets means?
完成的
添加一条评论
Did you replaced the antenna ? or only checked the brakets ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
S Rose 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,111
